Uszkodzony caravan
magic39
2 minuty temu, magic39 napisał(a):
Pytam o kategorie przyczepy.W uk auta uszkodzone maja kategorie,to pewnie pr,yczepy tez
Nie sądzę aby przyczepy miały kategorie, bo tam przyczep się nie rejestruje przecież, więc oficjalnie nikt nic o nich nie wie :)
  • Piotrek zmienił(a) tytuł na Uszkodzony caravan
Dla zainteresowanych, jeśli to o to chodzi, to są kategorie pojazdu po szkodzie które m.in. określają czy może wrócić na drogę. Z tego co wiem to N/S chyba jest nowe i zastąpiło C/D.
Cytat
If your insurance provider decides your car is a write-off, it will fall into one of the following categories:
Category A (scrap)
Your car is too damaged or old for repair. The entire vehicle should be crushed and can’t be used for parts.
Category B (break)
Your car is too damaged or old for repair but some parts may be re-used or sold second-hand, as long as they’re removed by an expert. A Category B write-off can’t be sold second-hand as a complete vehicle.
Category C (too expensive to repair)
Cars in this category can be repaired, but those repairs would cost more than the vehicle’s worth. You can continue to use the car if it’s repaired to a roadworthy condition.
Category D (total costs make it too expensive to repair)
The cost of repairs may be less than the vehicle’s worth, but other costs, like transporting the vehicle, take it over the limit of its value. You can use the vehicle if it’s repaired to a roadworthy condition.
There’s no need to re-register Category D cars with the DVLA before taking to the road again, but you’ll need to notify them that your car was written off.
Category N (non-structurally damaged repairable)
Category N vehicles can be repaired. These vehicles have only been damaged superficially and the structural integrity of the vehicle remains intact.
There’s no need to re-register Category N cars with the DVLA but you’ll need to notify them that your car was written off.
Category S (structurally damaged repairable)
These cars have structural damage but can be repaired. All Category S cars will need to be re-registered with the DVLA before being put back on the road.
https://www.comparethemarket.com/car-insurance/content/what-happens-if-my-car-is-written-off/
